Using VPN300 as AP Controller
I have two idea:
1)VPN300 as internal DHCP server or Relay DHCP server and only leave intranet cable.
(I'm not sure if thin AP can fetch address when interface set relay dhcp..)
2)Using Secure Wifi Solution but it need additional cost.
i have been try out using ZyWall 110. It seems to work just using the OPT port to get an IP and add access point to it without it working as a router or gateway.0 -
it should the same as Zywall 110.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
