SSL secuextender disconnect upon connection
2»
  • Alanl
    Alanl Posts: 15  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    I thought there might be a bad driver.
    I removed all the Intel Killer driver package and the Zyxel software. I rebooted and only used the native Windows Wi-Fi drivers along with the Secuextender. This produced the same result. The connection disconnect within 3-5 seconds of the connection before I can authorize the connection via 2FA.
    I then reinstalled all the Killer drivers and tested again, the result was the same disconnection. I can however still connect via L2TP.
    Regards,
    Alan
    PeterUK Posts: 4,050  Guru Member
    Can you disable 2FA?
  • Zyxel_James
    Zyxel_James Posts: 788  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @Alanl I would like to check on your Windows 11 PC. I've contact you throught private message, please check your inbox, thank you.
