Geoip database won't update. Firmware 4.73 sp2. Last update is 28.05.2023.
Best Answers
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,417  Zyxel Employee
    Hi @KFLarsen,
    The latest Geo IP version is 20230518.
    Recently, the Geo-IP DB file cannot be compressed completely and we will fix it in the next version 5.37.
  • Zyxel_Emily
    Hi @MarkoD,
    Recently, the Geo-IP DB file cannot be compressed completely and the issue will be fixed in 5.37. We stop releasing new GeoIP version until 5.37 is released. The database of GeoIP for 5.37(ATP/USG FLEX) and 4.73(USG/ZyWALL) are the same. Hence, the latest GeoIP version for 4.73 also stays at version 20230518. The GeoIP version will start updating after Jul. 10th.
«1
  • mMontana
    mMontana Posts: 1,425  Guru Member
    Zyxel Certified Network Administrator - Switch 50 Answers 1000 Comments Friend Collector
    Same here. But the DB is dated 15/05/2023. Firmware version 5.35P2.
    logs report
    2023-06-08 13:51:23
    notice
    myZyXEL.com
    Geo-IP country database is latest.
  • Zyxel_Emily
    Hi @KFLarsen,
  • KFLarsen
    KFLarsen Posts: 6
    Thanks. I'll wait for that…
  • mMontana
    Ok… didn't read that. Sorry, my bad.
    On the roadmap, is there a fix for 4.x firmware also?
    PeterUK Posts: 3,744  Guru Member
    On my flex 200 I can update to 20230518 fine it may be the case that Zywall has changed the compressed that stops the older Zywall from being able to update I mean even my USG60W no longer gets the updated AP firmware any more :(
  • MarkoD
    MarkoD Posts: 66  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Yes, Zyxel, I hope you'll also fix this for USG40/60/W!
  • MarkoD
    @Zyxel_Emily I home you'll also fix the GEO IP database for USG40/60/W
  • Zyxel_Emily
    Hi @MarkoD,
  • MarkoD
    Dear @Zyxel_Emily,
    Thank you for replying so quicky. Do I understand correctly that USG40/60/W with FW 4.73 will also start to update their GeoIP DB after July 10th?
  • Zyxel_Emily
    Hi @MarkoD,
    Yes, USG40/60/W with FW 4.73 is able to update GeoIP DB after July 10th.
