Zywall 310 - Multi spte VPN - Client L2tp Cant browse remote sites
Afternoon
Ive a multi site VPN setup, a zywall 310 is at the hub site. 5 remote sites inter-routing ok (am using the VPN concentrator feature)
Ive now setup Mac VPN clients, Then connect to the hub site ok and can ping / browse that hub sites LAN ok.
However i am unable to ping any other site.
When doing a trace route to a remote site lan the third hop is the WAN ip of the hub site.
Good answer.On thinking about your answer, I do have intersite routig working ok betweek site - site vpn.I notice I cannot add the L2TP VPN into the VPN concentrator.Should I be looking at policy routes0
Hi @Emerald,
The concentrator is configured on the hub site and L2TP VPN client is connected to the hub.
Create a policy route on the hub site and the spoke site respectively.
Hub
Incoming: L2TP VPN tunnel
Destination Address: Subnet of spoke_1 site
Next-Hop: site to site VPN tunnel between hub and spoke_1
Spoke_1
Source Addrsss: Subnet of spoke_1 site
Destination Address: L2TP VPN pool of the hub site
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
