Update USG60 from 4.33 to 4.73
Giovanni
Giovanni Posts: 2  Freshman Member
Hi all,
I'm a bit confused. I have a 4.33 firmware on USG60 and I would like to update to the lastest version 4.73. Can I have apply the 4.73 firmware directly or before I need to install the 4.38 then the 4.65 and last the 4.70?
    PeterUK Posts: 3,983  Guru Member
    you can try and update to 4.73 or get old firmware here
    https://support.zyxel.eu/hc/en-us/articles/360013941859-Security-Products-Firmware-Overview-FLEX-ATP-USG-VPN-ZYWALL-
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,538  Zyxel Employee
    Hi @GIOMIND ,
    Don't forget back up both device's startup configuration file before you perform firmware update.
