Is there a way to suggest new apps for app patrol? Looking for ooma VOIP
As I am getting accustomed to using AppPatrol vs opening ports manually I coudl not get ooma VOIP to work using app patrol and had to revert to configuring ports.
Ooma uses:
- remote UDP/TCP 53, 1194, 1294
- remote TCP 80, 110, 443
- remote UDP 67, 123, 3480
- local UDP 49000 to 50000
- remote UDP 10000 to 20000
Does Zyxel take suggestions?
Hello @tesagig
Do you want to use App Patrol to block ooma related Apps, right? Or, do you have other specific purposes? Thanks.
no, to enable (outgoing ports) on my outgoing internet traffic. Currently, I have a custom security policy setup for this.
- 588 USG FLEX H Series
- 477 News and Release
