SNMP Monitor USG60 WAN1 and WAN2 traffic?
Hi @TAPTech,
You can use OID: .1.3.6.1.2.1.2.2 to get ifInOctets and ifOutOctets of each interface.
Then calculate the bandwidth by using the value of ifInOctets and ifOutOctets.
(ifInOctets(time2) - ifInOctets(time1)) / (time2 - time1)
(ifOutOctets(time2) - ifOutOctets(time1)) / (time2 - time1)
Here is an example for your reference.
If you want to get the bandwidth which is received on the interface (ifInOctets)WAN2 (eth1) during the period
Time (17:00) : 50845741 bytes
Time (17:05) : 3589025121 bytes
Bandwidth : (3589025121 – 50845741)(bytes) / 300(seconds) = 11.79 MB
5
Hi @TAPTech,
5 -
That was a fantastic post and had everything I needed! Thank you so much.0
- 217 Nebula Ideas
- 576 USG FLEX H Series
- 297 Service & License
- 474 News and Release
