USG110 best WiFi AP settings for internet only
I would like to get advice on setting up (or changing) WiFi security
and setting USG110 for internet connection via AP DLink.
Now I have the following setup:
USG110 gate 192.168.271.254
AP DLink connected to LAN.
WAN 192.168.271.252
LAN 192.168.1.1
assigns DHCP 192.168.1.100-200
The AP should ONLY be used to connect to the Internet (not to the LAN).
AP - current FW, WPA2/PSK, hidden SSID, whitelist of allowed MAC addresses.
Unfortunately, I also ping the internal network 192.168.271.254, map the disk, etc.
How best to set the option to connect only to the Internet (by AP) in this configuration?
a)
should I connect the AP to another port on the firewall and set a rule for AP ?
b)
Or is it sufficient to set routing for 192.168.271.252 on the firewall?
Question :
This is rather general ... it can be said that I have done the maximum possible in terms of security -
(WPA2/PSK, hidden SSID, whitelist of allowed MAC addresses) + additional adjustment a) or b) ?
Thanks for tips or anwers ...
Vaclav
This AP Dlink is a router being used as a AP? You likely want to put it on another port of the USG and not use the WAN port on Dlink then without rules like LAN to ANY but LAN to WAN or give interface it own zone
Hi @kyssling,
On the AP DLink, check if it has the operation mode such as “Access Point” or "bridge mode" and select this operation mode. Connect the AP to another lan interface and assign this lan interface to another zone. Then create security policy rules to block this zone from accessing other lan zones.
Hello, thank you for advice, can I ask for more detail ...
I connect AP to port 5 on USG110 and set it as LAN2. IP address on port 5 (LAN2) 192.168.2.1 (DHCP, DNS set)
What minimum PolicyControl do I need to set (only for internet web browsing on cellphone or tablets connected via AP - no VPN etc.)
LAN2 to WAN allow
LAN1 to LAN2 deny
LAN2 to LAN1 deny
LAN2 to Zywall deny (?)
WAN to LAN2 deny (?)Thank you !
Default rules for LAN1 and LAN2 is to ANY so you want to change that to WAN so that LAN2 can't get to LAN1
As for internet web browsing only you can make a group of services with 80(HTTP), 123(NTP), 443 (HTTPS) 53 (DNS)? unless you go from LAN2 to Zywall for DNS games can be blocked by this limited group
- 588 USG FLEX H Series
- 477 News and Release
