GS1910-24 VLAN / Trunk-Port
klaeuser
klaeuser Posts: 6
I have a trunk cable (that comes from a router) which delivers the VLANs 40,60,70,80.
Now I need to "split" that trunk to individual ports so that I can connect devices there.
Devices are not capable to handle VLAN tags, therefore they must be removed on egress.
On ingress the VLAN id must be added.
I've tried that with VLAN id 40 … but no success.
What is my mistake?
  • klaeuser
    klaeuser Posts: 6
    maybe I need to explain the picture…
    The trunk comes in on port 20 - therefore all incoming traffic should be tagged.
    Ports 21 …24 will be connected to devices that cannot handle VLAN tags - therefore all incoming traffic should be untagged there.
    In this example I want to use VLAN id 40 on ports 21 - 24 - but I get no link.
    When I e.g. connect a computer to one of these ports - I cannot connect to the network. I don't use DHCP in this scenario - the computer is configured to an certain IP (in this case 10.0.40.44)
    PeterUK Posts: 3,887  Guru Member
    edited June 2023
    Can't find a manual for GS1910 the picture without a header of what they are makes it hard my GS2210 for doing your setup is easier along with other models.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,526  Zyxel Employee
    edited June 2023
    Hi @klaeuser,
    The ingress acceptance you can apply "tagged and untagged" for all ports.
    The VLAN config for port 20:
    1. Port VLAN should be "1" if your management VLAN is 1.
    2. Egress tagging should be "Untag port VLAN".
    3. Allowed VLAN should be "1, 40, 60, 70, 80".
    The VLAN config for ports 21-24:
    1. Port VLAN should be "40".
    3. Allowed VLAN should be "40".
    Zyxel Melen
