ZyWall freezes. Only a power restart helps
TeddyRipper
Hello. I have a ZyXel ZyWall 110 installed, it has been working for several years without problems. Suddenly it started to freeze, at the moment of freezing the local network, the Internet stops working (sometimes the RDP connection does not break). If I disconnect the network cable, the indication on the port remains (the orange indicator is on without blinking). Only restarting the device by power helps. The problem recurs 2 or 3 times a day with an interval of 5-7 hours. I checked the local network and PC, this is not the source of the problem. Firmware Version V4.62(AAAA.0) Please advise what can be done in this situation.
Download new firmware unplug from WAN reboot install
@TeddyRipper Your device may encounter this
Please upgrade to the latest firmware version v4.73P2 and check if this behavior still exists
Updated the firmware to version V4.73(AAAA.2) Running Zywall 110 V4.73(AAAA.2) While I'm watching how ZyWall behaves
I suggest you upgrade both partitions to 4.73P2
from version 4.33 immediately upgrade to 4.73P2? How to do it (I updated via FTP)? And for what?
Just upgrade directly at once if you don't have complex settings inside. Remember to backup your settings before doing so
Updated. It's been two weeks since the update. Everything works great! Thanks for the help! :)
- 439 Beta Program
- 2.8K Nebula
- 203 Nebula Ideas
- 522 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 4.4K FAQ
- 98 Security Highlight
