Unmanaged Switch MG105 - ping ok, internet ko
Hi @Zotme,
Could you help to verify the below question when the client connects to the MG105?
- Could you help to collect
ipconfig /all
(Window) information for me to check if the client gets the IP address/default gateway/DNS server settings? - Can the client resolve the domain? Please use
nslookup
to check. - What's your OS version / Nic model / Nic driver version?
0 - Could you help to collect
Hi
I've two switch MG-105, in the same configuration router-pc-cables, one works the other no…
Windows 11 22H2
Intel(R) Ethernet Controller I225-V
Intel - 05/03/2022 - 1.1.3.28Same ipconfig /all with both switchs.
Hi @Zotme,
Thanks for providing your device information. But since you mention one MG-105 works and another does not, the problem is more likely on the MG-105. Could you provide the serial number of the two MG-105 for me to check the difference?
Zyxel Melen0 -
ko S224331001240
ok S224329000256
Thanks!
Hi @Zotme,
Thanks for the information. By the way, could you also help
nslookup d.nebula.zyxel.com
andtracert 8.8.8.8
between the two switches? I would like to confirm your internet has no problem.Zyxel Melen0 -
Sure!
MG-105 OK
C:\Windows\System32>nslookup d.nebula.zyxel.com
Server: TUF-AX6000-6F82
Address: 192.168.50.1Risposta da un server non autorevole:
Nome: d.nebula.zyxel.com
Addresses: 34.246.20.161
52.48.115.44
52.210.12.1
52.210.229.217
54.73.103.137
54.76.217.223
54.154.22.135
63.32.141.172
34.243.116.158
34.245.88.134C:\Windows\System32>
C:\Windows\System32>tracert 8.8.8.8
Traccia instradamento verso dns.google [8.8.8.8]
su un massimo di 30 punti di passaggio:1 <1 ms <1 ms <1 ms TUF-AX6000-6F82 [192.168.50.1]
2 9 ms 9 ms 9 ms 100.64.255.255
3 9 ms 9 ms 9 ms net225-27-32-195.dimensionesrl.eu [195.32.27.225]
4 9 ms 9 ms 9 ms net246-27-32-195.dimensionesrl.eu [195.32.27.246]
5 8 ms 9 ms 9 ms 72.14.221.8
6 9 ms 9 ms 9 ms 108.170.245.65
7 9 ms 9 ms 9 ms 142.251.235.173
8 9 ms 9 ms 9 ms dns.google [8.8.8.8]Traccia completata.
MG-105 NO OK
34.245.88.134
34.243.116.158
63.32.141.172
54.154.22.135
54.76.217.223
54.73.103.137
52.210.229.217
52.210.12.1
52.48.115.44C:\Windows\System32>tracert 8.8.8.8
3 8 ms 9 ms 9 ms 195.32.27.225
4 9 ms 9 ms 9 ms 195.32.27.246
5 13 ms 9 ms 9 ms 72.14.221.8
8 9 ms 8 ms 8 ms dns.google [8.8.8.8]Traccia completata.
unplug the switch that works and test the switch that does not to see if it works also unplug replug Ethernet to the switch to trigger DHCP
tried several times, don't work….
You can ping 8.8.8.8 and DNS 192.168.50.1 through the switch and it being Unmanaged there is no traffic it can block.
get tcping
https://download.elifulkerson.com/files/tcping/0.39/x64/
run in cmd
tcping64 8.8.8.8 53
Probing 8.8.8.8:53/tcp - Port is open - time=9.933ms
Probing 8.8.8.8:53/tcp - Port is open - time=9.893ms
Probing 8.8.8.8:53/tcp - Port is open - time=10.077ms
Probing 8.8.8.8:53/tcp - Port is open - time=9.602ms
Ping statistics for 8.8.8.8:53
4 probes sent.
4 successful, 0 failed. (0.00% fail)
Approximate trip times in milli-seconds:
Minimum = 9.602ms, Maximum = 10.077ms, Average = 9.876msNo internet in Chrome, Brave, Steam client, etc…
New test... Macbook Air with an hub usb with ethernet. Get an IP from DHCP. no internet.0
- 417 Beta Program
- 2.5K Nebula
- 160 Nebula Ideas
- 108 Nebula Status and Incidents
- 5.9K Security
- 331 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 259 Service & License
- 402 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 80 Security Highlight
