Zywall 310 - Multi spte VPN - Client L2tp Cant browse remote sites
Afternoon
Ive a multi site VPN setup, a zywall 310 is at the hub site. 5 remote sites inter-routing ok (am using the VPN concentrator feature)
Ive now setup Mac VPN clients, Then connect to the hub site ok and can ping / browse that hub sites LAN ok.
However i am unable to ping any other site.
When doing a trace route to a remote site lan the third hop is the WAN ip of the hub site.
Good answer.On thinking about your answer, I do have intersite routig working ok betweek site - site vpn.I notice I cannot add the L2TP VPN into the VPN concentrator.Should I be looking at policy routes0
Hi @Emerald,
The concentrator is configured on the hub site and L2TP VPN client is connected to the hub.
Create a policy route on the hub site and the spoke site respectively.
Hub
Incoming: L2TP VPN tunnel
Destination Address: Subnet of spoke_1 site
Next-Hop: site to site VPN tunnel between hub and spoke_1
Spoke_1
Source Addrsss: Subnet of spoke_1 site
Destination Address: L2TP VPN pool of the hub site
- 588 USG FLEX H Series
- 476 News and Release
