Migrate configuration
Hello @RikHead
Our online converter could transfer the configuration from USG110 to USG FLEX 500. You may transfer it to USG FLEX 500 first, and then manually adjust it to the configuration of USG FLEX 200.
You can provide it to me through private message, and I will do it for you.0 -
Thanks for answers, i tried but it doesn't work. I patched the old USG110 to the new 4.73(2) firmware version, i do the same thing to the last one version in USG FLEX 200 device. There is a step by step guide to import old firewall configuration into the new?
Do you encounter anything with the steps below
- Please backup the configuration on USG100 4.73P2
- Convert the configuration to USG FLEX 500 via online converter
- Manually adjust the configuration to USG FLEX 200
- Upgrade the USG FLEX 200 to the latest version 5.36P2.
- Upload the configuration to USG FLEX 200.
May I know how it failed? upload configure fails?
You can send the configuration to me through private message, I will do it for you.James
- 588 USG FLEX H Series
- 476 News and Release
