GS1900-24 Support
I have a few questions before I help decide should I buy a used GS1900-24 or not. I'm including a copy of the info I have on the item:
1/ Is this product still being supported or is it EOL?
2/ Can I update the firmware to v2.7
3/ Is there a version 2 of GS1900-24
Any help will be greatly appreciated
Hi @khwatson,
> This is still supported, only GS1900-24HP and GS1900-48HP been EOL.2/ Can I update the firmware to v2.7?
> Yes, you can update the firmware to the latest firmware (v2.70 patch 5).3/ Is there a version 2 of GS1900-24?
> Only PoE model of GS1900 has version 2 model.Zyxel Melen0
Hi @khwatson,
> Only PoE model of GS1900 has version 2 model.Zyxel Melen0 -
thank you
- 211 Nebula Ideas
- 545 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 465 News and Release
