uplink GS-1920-24 v2 switchs
Alevideotest
Alevideotest Posts: 1 image  Freshman Member
Hello everyone,
I need advice to connect 2 GS1920-24 v2, with transreceiver modules and a fiber optic cable about 100m long.
I just want to know if it is possible to do this with Zyxel SFP-SX-D modules.
Thank you
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @Alevideotest,
    Yes, you can do it with Zyxel SFP-SX-D. Its max transmission distance is 550m.
    Kindly remind, the optical fiber cable should be multi-mode.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Alevideotest,
    Zyxel Melen
