VPN+IPSEC+L2TP+CERTIFICATE to host xubuntu 18.04
It seems your issue is about the certificate. I suppose you need to add the CA public certificate in the Linux certificate store ( /etc/ssl/certs) and/or in the ipsec certificate store (/etc/ipsec.d/cacerts)
you may check it
https://kifarunix.com/how-to-configure-ipsec-vpn-using-strongswan-on-ubuntu-18-04/
you may check it
thanks
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
