sfp wan atp100
the Vlan to configure to por sfp gpon - via WAN
User Vlan Dati 835
User Vlan Voce 837
User Vlan Video 836
Vlan Gpon Dati 100
Vlan Gpon Voce 101
Vlan Gpon Video Multicast 3585
Tipo Segnale Ottico GPON0 -
Schema a blocchi di una rete GPON. Vengono utilizzate, nel complesso, tre diverse lunghezze d’onda: 1490 nm per la ricezione, 1310 nm per la trasmissione e 1550 nm per i servizi in overlay.
Hi @leonardo
Do you want to configure VLAN interfaces on the SFP port, right? If so, will the SFP port belong to WAN or LAN role? If you could share the topology with us and that would be better. Thanks.
Maybe you could refer to this similar discussion for the VLAN settings on the SFP port and you could configure VLAN tag on the WAN port of SFP interface as well.
I would like to use the SFP gpon module of the ATP100 to connect directly to the FTTH ADSL line....
the atp100 will be ONT (optical network terminationi) at home
Hi @leonardo
If you configure VLAN ID on the SFP wan port and the outgoing traffic would be tagged the VLAN ID only, as below:
But if you want to prioritize voice, video, or other specific traffic, we suggest you could use the BWM feature. Thanks.
thanks
Using an external media converter to transform FO to electrical ETH works (port2). By inserting the technicolor GPON (2.5Gbps/1.25Gbps-(FTTH SFP GPON Technicolor AFM0002TIM)) module into modulo SFP (port1) to the ATP100W It still don't go online.
Hi @leonardo
"By inserting the technicolor GPON (2.5Gbps/1.25Gbps-(FTTH SFP GPON Technicolor AFM0002TIM))module into modulo SFP (port1) to the ATP100W It still don't go online."
Do you mean the SFP port of ATP100W is not working?
Could you use the below CLI to check whether the SFP port is working or not?
(1). show interface all ⇒ to check all interfaces' status
(2). ping 8.8.8.8 interface sfp ⇒ to verify the SFP port can ping 8.8.8.8 normally or not
Thanks.
- 588 USG FLEX H Series
- 476 News and Release
