GS1900-24 Support
khwatson
khwatson Posts: 56 image  Ally Member
I have a few questions before I help decide should I buy a used GS1900-24 or not. I'm including a copy of the info I have on the item:
1/ Is this product still being supported or is it EOL?
2/ Can I update the firmware to v2.7
3/ Is there a version 2 of GS1900-24
Any help will be greatly appreciated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,631 image  Zyxel Employee
    Hi @khwatson,
    > This is still supported, only GS1900-24HP and GS1900-48HP been EOL.
    2/ Can I update the firmware to v2.7?
    > Yes, you can update the firmware to the latest firmware (v2.70 patch 5).
    3/ Is there a version 2 of GS1900-24?
    > Only PoE model of GS1900 has version 2 model.
    Zyxel Melen
  • Zyxel_Melen
    Hi @khwatson,
    Zyxel Melen
  • khwatson
    thank you
