USG40Upgrade
rgill70
rgill70 Posts: 1 image  Freshman Member
Looking to move up as the USG40 no longer handles the internet connection (maxes out at 400mb). So getting a USGFlex200.
To migrate would I run the converter from USG40 to Flex100. Then is there some manual items to edit in the config to make it Flex200 compatible?
Just hate to have to enter all this manually over again.
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    edited June 2023 Answer ✓
    It should be compatible. Just remove first three line where have moudle/version informatin and add another WAN2 manually.
  • WJS
