Zyxel USG FLEX 50 - temperature check
MitjaS3NEXT
MitjaS3NEXT Posts: 7  Freshman Member
Is there any way to check the temperature of the unit with GUI or CLI?
  • Zyxel_James
    Zyxel_James Posts: 718  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @MitjaS3NEXT sorry, I have to correct my statement.
    The correct way to check the device temperature is
    Router# debug hardware
    Router(debug hardware)#
    Router(debug hardware)# fan-get
    Sensor[0]:56 degree
    Sensor[1]:35 degree
    Sensor[2]:40 degree
    FAN[0]:5781 RPM
    FAN[1]:5750 RPM
    FAN[2]:5775 RPM
    FAN[3]:5763 RPM
    However, USG FLEX 50 is a smaller model that does not have fans. So you cannot check the temperature of the unit for USG FLEX 50
  • smb_corp_user
    smb_corp_user Posts: 168  Master Member
    Try the command set
    >debug hardware fan-get
    I am uncertain if this works as a complete string or 2 commands, so another option is
    >debug hardware
    >fan-get
  • MitjaS3NEXT
    fan-get command does not work. See screenshot.
    PeterUK Posts: 3,770  Guru Member
    edited June 2023
    Its unlikely the FLEX 50 supports giving you the temp only on higher models
  • Zyxel_James
    @smb_corp_user USG FLEX 50 does not have a fan.
    @MitjaS3NEXT Please try show cpu-temperature-monitor
  • MitjaS3NEXT
    edited July 2023
    I always get "command not found", when I try "show cpu-temperature-monitor"
    See the screenshot.
  • Zyxel_James
    Sensor[0]:56 degree
    Sensor[1]:35 degree
    Sensor[2]:40 degree
    FAN[0]:5781 RPM
    FAN[1]:5750 RPM
    FAN[2]:5775 RPM
    FAN[3]:5763 RPM
