Zyxel USG FLEX 50 - temperature check
Is there any way to check the temperature of the unit with GUI or CLI?
@MitjaS3NEXT sorry, I have to correct my statement.
The correct way to check the device temperature is
Router# debug hardware
Router(debug hardware)#
Router(debug hardware)# fan-get
Sensor[0]:56 degree
Sensor[1]:35 degree
Sensor[2]:40 degree
FAN[0]:5781 RPM
FAN[1]:5750 RPM
FAN[2]:5775 RPM
FAN[3]:5763 RPMHowever, USG FLEX 50 is a smaller model that does not have fans. So you cannot check the temperature of the unit for USG FLEX 50
Try the command set
>debug hardware fan-getI am uncertain if this works as a complete string or 2 commands, so another option is
>debug hardware>fan-get0 -
fan-get command does not work. See screenshot.
Its unlikely the FLEX 50 supports giving you the temp only on higher models
@smb_corp_user USG FLEX 50 does not have a fan.
@MitjaS3NEXT Please try show cpu-temperature-monitor
I always get "command not found", when I try "
show cpu-temperature-monitor"See the screenshot.
Sensor[0]:56 degree
Sensor[1]:35 degree
Sensor[2]:40 degree
FAN[0]:5781 RPM
FAN[1]:5750 RPM
FAN[2]:5775 RPM
- 588 USG FLEX H Series
- 477 News and Release
