Add GEO blocking option in Email security rules - Black/White List
Przemek
Przemek Posts: 28 image  Freshman Member
edited July 2024 in Security Ideas
I wish I have in Black/White List an option for GEOGRAPHY blocking. And block all emails sent from blocked countries.
1 votes
Active · Last Updated
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    You can.
    Create a group composed from the countries you want to block. Let's call that "Email_Block".
    Then configure incoming communications on port 25, 465, 587 to being blocked from the group.
  • Przemek
    It looks like blocking GEO Group from accessing my network ports.
    Will it block emails sent to external hosting and downloaded to my network from there?
    I was thinking about Rule creating here:
  • nielsscheldeman
    nielsscheldeman Posts: 94 image  Ally Member
    Do you have your own mailserver or are you working with something like Office 365? This could only work if you use your own mailserver.
  • Przemek
    I have my own mail server.
    If I have an IP option in rules GEO option should not be something impossible to add here.
  • nielsscheldeman
    You have to block these ports then in your Policy Control. Now you have a policy From "WAN" to "LAN1", IPv4 Source "Any", IPv4 Destination "mailserver", Service "25, 465, 587".
    First create objects → Address, Type Geography and select the countries you wish to allow (you can also work reverse and block only countries, but then you need to create an extra rule with higher priority to block these first). Put them in an address group, let's say GEOALLOW.
    Now in case you only want to allow some countries, change your Policy Control rule. Change IPv4 Source "Any" to this object "GEOALLOW"
