USG60 Broadcast 224.0.0.1
The logs on our USG60 appear to be showing that the Firewall is trying to broadcast to 224.0.0.1 every two minutes and being blocked by the Rules.
Can anyone tell me why and what it is trying to do sending to this IP address and is there any way of stopping it trying to do it in the first place?
Hi @flookyk
224.0.0.1 is a multicast ip address, and it 224.0.0.1 is used for query messages and is assigned to the permanent group of all IP hosts (including gateways).
I suppose the USG60 supports both IGMP version 1 (IGMP-v1) and IGMP version 2 (IGMP-v2). At start up, the USG60 queries all directly connected networks to gather group membership. After that, the USG60 periodically updates this information.
IP multicasting can be enabled/disabled on the ZyWALL LAN and/or WAN interfaces in the web configurator (LAN; WAN). Select None to disable IP multicasting on these interfaces. Use this screen to configure LAN DHCP and TCP/IP settings.
I suppose configuration on USG60 is very similar.
Regards0 -
If this is the IGMP setting, then the tick is not in the box to enable it??
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 465 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
