UTM USG60
I'm performing some throughput test on my new USG60, and I have activated UTM license.
A speedtest connected directly to modem give me around 750/280 Mbps (up/down), meanwhile performing the same speedtest on my USG 60 give me 265/221 Mbps (up/down), no rules are using UTM services.
Is it possible to stop UTM service to test the throughput? from datasheet the throughput must be gigabit.
Best Regards
eze
Hi all
RFC2544 is the Benchmarking Methodology for Network Interconnect Devices.
Most vendors use it to do the System & Capacity Performance.
It recommends doing the tests with different frame sizes, for example, frame sizes to be used on Ethernet: 64, 128, 256, 512, 1024, 1280, 1518.
As far as I know, Zyxel only publishes one result: Maximum throughput based on RFC 2544 (1,518-byte UDP packets). https://www.zyxel.com/products_services/Unified-Security-Gateway-USG40-40W-60-60W/comparison#specifications
Some vendors are more clear, and they publish more details about the benchmark.
Although from the datasheet, the theoretical best throughput is 1 gigabit, the real throughput could be much lower (depends on your traffic characteristic).
My experience shows me that you can feel lucky if you get 50% of the throughput of any vendor datasheet.
I hope you can tune the device to get bigger throughput.
Regards0 -
Hi @ezekiel74,
In our lab test with 1G connection, the Speed Test result for USG60 with firmware4.32 is as follows.
Ethernet Throughput (With Firewall Routing, NAT and ADP enabled)
http(download) 671.96 Mbps
http(upload) 455.33 Mbps
If UTM licenses are activated, UTM profiles are created but not applied to security policy rule, the throughput is not affected by UTM services.
I run several tests with different conditions and the download/upload speed on SpeedTest is around 250Mbps/100Mbps.
ISP: 300Mbps/100Mbps
1. ISP-----PC
2. ISP---(WAN)USG60(LAN)---PC; default settings with UTM license activated, firewall is disabled.
3. ISP---(WAN)USG60(LAN)---PC; default settings with UTM license activated, firewall is enabled.
4. ISP---(WAN)USG60(LAN)---PC; default settings with UTM license activated, firewall is enabled. Create a profile on CF/IDP/App Patrol. Profiles are not applied to any firewall rule.
In your test, if UTM rules are not applied to firewall rules but the throughput is still low, please share your configuration file with us to check.
Hi @Zyxel_Emily ,
Thanks a lot for your explanation, I'll perform other tests and in case I'll send you my configuration.
Best Regards
eze0
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
