Zyxel USG 60 map IPSec VPN connection
2»
    PeterUK Posts: 4,446 image  Guru Member
    is it a Site to site or Remote Access (Server Role) ?
    It might help if you draw out the network layout my test was done with Remote Access (Server Role) going to a client down the VPN for NAT rule.
    edited July 2023
    Got some bad news testing here with Remote Access (Server Role) on the other end and you being the Remote Access (client Role) to forward a port by way if design can not be done. I can get a TCP SYN by ShieldsUP! to the IP down the VPN but getting a SYN, ACK back is not possible that way round if you was the Server Role then it should be possible to forward a port to a client.
  • andrew8891821
    andrew8891821 Posts: 8 image  Freshman Member
    Thank you for your help. So I assume there is no other way to get access to that resource from outside LAN?
    You would need to set a Remote Access (Server Role) your end with local IP 0.0.0.0
    and setup a Remote Access (client Role) on the other end with local IP your subnet with remote policy 0.0.0.0 then you can NAT a port with your end routing rule
    incoming WAN
    service your port
    next hop VPN Tunnel your VPN server
    on the other end
    incoming LAN
    click advanced source port your port
    next hop VPN Tunnel your VPN client
    and some firewall rules IPSec_VPN to LAN and your end WAN to IPSec_VPN
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @andrew8891821
    Welcome to the Zyxel community and thanks for your inquiry. Regarding your requirement "What I need to do is give access to that resource to one PC from outside. E.g. PC X with public IP X.X.X.X can connect VPN host 192.168.200.80 by accessing my Zyxel WAN_IP:VPN-HOST_PORT.".
    Currently, we don't support this scenario. We suggest the outside PC get a VPN IP address(such as 192.168.200.XX) and connect to the VPN host 192.168.200.80, please ensure the security policy allows VPN IPs can connect to each other. Thanks.
