USG310 2 ISP
Hmm. 192.168.xxx.1 on a WAN interface, that is curious. Makes me think that the WAN interface is connected to another interface before accessing the internet … or some sort of virtualization at the ISP side?
Not sure if this can be done, but I might be wrong since I don't know all the details of USG310.
The main challenge here is that you need to combine Load Balancing with Routing and the "trunk" physical connection. Looking through search results, it seems there are other products, both software and hardware, which could do the job, although VPN might not be what you are looking for to gain the extra speed from 2 ISP connections.
If this can be done on the USG310, and I don't even know whether it can be done via wizard guides, it would probably have to combine trunking, Load Balancing and Routing in one big setup.
I think the br1 for load balancer is the interface and not traffic going through the bridge.
I'm guess your 2nd ISP you want the WAN IP to device? Or is it from another router doing NAT? Can this router for 2nd ISP do static route?
To device(USG directly) PPPoE and 2nd from gpon connected.
So what IP you get by 2nd connected?
what is your interface LAN IP subnet PC's get by USG310 ?
what interfaces are you using for br1?
Okay, see separetly both works, when WAN 1 with PPPoE is active and i Active BR1 it on;y works WAN by BR1. Ip get from gpon router to ge2 interface and to br1
WAN1 i am using GE1 and for 2nd i am using GE2
but why the bridge br1?
Without BR1 internet not working.
So the WAN IP you get from what my IP site is only from gpon router ISP your not using WAN 1 with PPPoE? What IP does your device get? is it from the bridge br1?
no see. From PPPoE it gets static public ip and it is connected to GE1 and 2 ISP GPON and it is using own router from router it is going to USG 310 by DHCP and gets ip 192.168.100.4 port GE2 and BR1 are same. here static route only showing ISP one
internal ip address up there
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 466 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
