Connectivity Check on interface with domains
PeterUK
PeterUK Posts: 4,415 image  Guru Member
edited July 2023 in Security
VPN 300 V5.36(ABFC.2)
Using ge3 VLAN443 external
I get this every now and then about every 30 mins I have checked my DNS by Wireshark and can see the DNS answers being sent to the VPN300 on VLAN53 (DNS to my BIND has its own VLAN)
DNS forwarder
192.168.53.12 to BIND and 192.168.53.4 USG60
set with bounceme.net and no-ip.org with when probe succeeds when any one
here is another example
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Dear @PeterUK
    Could you share your topology with us? It's convenient for us to understand your finding. Thanks.
    edited July 2023
    It works for like 30 mins then does a DNS lookup and gets answer from BIND but the VPN300 choose not to accept the answer at times
    Here you go
    edited July 2023
    I'm not 100% sure I found the reason but I tried on FLEX200 and was not seeing a problem. I then added some WILDCARD FQDN in a group:
    *googlevideo.com
    *steamcontent.com
    *yahoo.com
    *youtube.com
    enabled BWM with a rule with that group then started seeing a problem.
    So a bug for DNS when the USG snoops DNS answers for WILDCARD FQDN?
