GS1900-10HP / 24HP get Consuming Power via SNMP
ChrisRaccon
ChrisRaccon Posts: 1 image  Freshman Member
edited July 2023 in Switch
is it possible to get the Consuming Power for each Port via SNMP for the GS1900-10HP or GS1900-24HP? With the MIB Browser I do not see these values. Are they not availible?
Regards,
Chris
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    edited July 2023 Answer ✓
    Hi Chris,
    The GS1900 series, including GS1900-10HP and GS1900-24HP, only supports the MIB files available on our official website. You can access them using this link: Zyxel GS1900 Series Download Page .
    In regard to your question about monitoring the power consumption for each port via SNMP, unfortunately, there is currently no OID for this function in the GS1900 series. However, for some other Zyxel switches like GS1920 series, you can use the following OID to monitor the total power consumption: .1.3.6.1.2.1.105.1.3.1.1.4.1
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi Chris,
    Zyxel_Judy
    Untitled Image
