Usg Flex 100: sometimes Nat rules stop working
Hi
I have an usg Flex 100 with latest firmware
After some year of perfect working from 1 month, sometimes, Nat rules stop working and the workstation software cant receive traffic from external call (external devices call the local software for record some status information)
Solution: uncheck Nat rules
Wait some minutes
Recheck Nat rules
I cant find other solution....
«1
  • Ps: VPN is disabled
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,317  Zyxel Employee
    edited May 2023
    Hi @LucaSantamarianova
    We suggest you can update to our latest firmware V5.36P2 for further verification. If it still has a problem, please share your running-config file with us via private message and indicate is which NAT rule cannot work sometimes. Thanks.
  • hi
    thanks for reply!
    after firmware updating ( more times, the last is V5.37(ABUH.0)) the issue is came back randomly another 2 times
    thanks
    PeterUK Posts: 3,770  Guru Member
    edited July 2023
    Never seem this problem what type of traffic is it?
    Try disable ADP
  • LucaSantamarianova
    LucaSantamarianova Posts: 10
    edited July 2023
    Small packet traffic from allarm systems (home and business)
  • The ADP Is already disabled
    Why would a alarm systems need inbound traffic? Thats bad it should be outgoing to a server
    how do you know its stopped working?
  • the USG FLEX is on a alarms installer.
    the systems of the various customers connect to communicate
    - the state in life
    - eventual alarms moreover,
    the control units report the lack of communication with my client's alarm centre
    also via direct connection (link to the web server of the alarm center pc hosted behind the USG http://333.555.222.111/subfolder ) technicians can access the system to verify customer problems etc.
    when the rules are blocked, the customers' systems are unable to send reports and are blocked, furthermore the system becomes unreachable at the address used by the technicians
    a simply deactivation and reactivation of the rules unlocks the issue
    edited July 2023
    Not sure it will help but try increasing UDP Session Time Out to 120 in Session control
    you could do a packet capture of the port will help
