Service License refresh sometimes use AUTO DNS
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited July 2023 in Security
VPN300 V5.37(ABFC.0)
In DNS forwarder I have
* 192.168.53.12 VLAN53
* 192.168.53.4 VLAN53
And AUTO default that I don't want to use and have blocked then upstream with a switch
When you do a Service License refresh it will sometime use AUTO and will fail refresh it again then it works
This problem could be solved by this
https://community.zyxel.com/en/discussion/10818/remove-auto-added-dns-as-forwarder
  • Zyxel_Cooldia
    edited July 2023 Answer ✓
    Update, we will add a option in interface to control request DNS option in next generation firewall(next platform).
  • Zyxel_Cooldia
    Hi @PeterUK ,
    Do you mean a setting to disable request DNS option when wan interface is DHCP or PPPoE?
    As in disable this
  • Zyxel_Cooldia
    Hi @PeterUK ,
    Thanks for update, i will submit a FRQ for internal evaluation.😀
  • Zyxel_Cooldia
