No ping from Zywall IPSEC VPN Client
Hi @VPNSFIN,
Use VPN100 with firmware 10.01(ABFV.1) to run the test and IPSec VPN client is able to ping local subnet of VPN100 successfully.
Topology:
(192.168.20.1)IPSec VPN client----Internet----(wan)VPN100(lan: 192.168.1.0/24)-----PC(192.168.1.34)
Once ZyWALL IPSec VPN client is installed on Windows, you'll find "TheGreenBow Virtual Miniport Adapter" in network adapter.
Please check if ZyWALL IPSec VPN client is installed successfully.
Can you share your configuration file of the VPN model with us in the private message?
VPN provisioning
In VPN connection on the VPN100, enable “Configuration Payload” and assign IP pool for IPSec VPN clients.
The tunnel is opened. IPSec VPN client gets IP 192.168.20.1 automatically. Ping PC 192.168.1.34 successfully.
- 601 USG FLEX H Series
- 480 News and Release
