How Do I do to connect a server at DMZ and post it with an public IP
dirodiro
dirodiro Posts: 6 image  Freshman Member
I configured my dmz sub net 10.10.10.0/255.255.255.0
the dmz ip is 10.10.10.1
i have connected a server 10.10.10.2
i have tested some routes and they have worked….,
but I need to assign a Public IP to the server and access it from out of the office, includding ports as: ftp, rdp, http, y sql, Please if you can help me, thank you
    PeterUK Posts: 4,446 image  Guru Member
    Well theirs a way to have the server have the real WAN IP even if you have one but for a simple setup the USG has your WAN IP and you can make NAT rule that are Virtual Server for the ports to your DMZ LAN server IP
  • dirodiro
    in fact, in this case, the WAN ip is different to the Server on DMZ, .. I already made NAT with external ip as the public and internal 10.10.10.2, I already made the policy with from, to and destination (my server)
    and it does not work yet
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Sounds like you have public IP on DMZ.
    Try to change type if you use pre-defined DMZ name.
    Router(config)# interface dmz
    Router(config-if-dmz)#type external
    And exit, save .
