I have a GS1900-24HP switch and in the management interface, most of the text does not appear...
Filipe_Branco
Could someone help me.
Same issue report before. Looks like the problem relate to browser and firmware 2.30 or above version can solve the problem.You can refer the following link to check more detail.
https://businessforum.zyxel.com/discussion/745/no-description-for-radio-buttons-on-gui-page-of-vlan-port-settings#latest
I am not sure the Internet Explorer can work correctly. You can have a try and upgrade to latest firmware to solve issue.
Another way is that you can use ZON Utility to upgrade firmware.
Hi @Filipe_Branco,
Welcome to Zyxel Community!
Regarding this event, the issue is related to browsers and already fixed by the latest firmware version.
Kindly enter this link then download and upload the 2.40 firmware version of GS1900-24HP.
Thanks for supporting Zyxel!Zyxel_Jonas0 -
Thank you!!!Ace said:Same issue report before. Looks like the problem relate to browser and firmware 2.30 or above version can solve the problem.You can refer the following link to check more detail.
I am a newbie and I am looking for solve this problem
thank you again0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
