How Do I convert a port to WAN2 in USG100Flex
dirodiro
dirodiro Posts: 6 image  Freshman Member
I need to connect 2 Wans, How can I convert a lan port to WAN?…,
thanks
  • mMontana
    mMontana Posts: 1,487 image  Guru Member
    Configuration → Port → Port Role.
    Row 1: LAN1
    Row 2: LAN2
    Row 3: DMZ
    Row 4: WAN
  • mMontana
    Row 1: LAN1
    Row 2: LAN2
    Row 3: DMZ
    Row 4: WAN
  • dirodiro
    ok, Thank you,
    sn't it necessary to make a policy?
    ok, i define the port as WAN2 and connect the ISP to it,
    Then how do I load balance?
    PeterUK Posts: 4,487 image  Guru Member
    edited August 2023
    The USG100Flex only has one Native untag WAN from what I can tell making P6 show as WAN does not change it type for internal to external for it to connect to a gateway.
    You can however add a VLAN to WAN base port for another external and you will need a switch to likely untag it to the internet.
  • mMontana
    @dirodiro mr @Zyxel_Jeff decided that my post was the answer.
    Did help solve your problem?
