How Do I convert a port to WAN2 in USG100Flex
Configuration → Port → Port Role.
Row 1: LAN1
Row 2: LAN2
Row 3: DMZ
Row 4: WAN1
Row 1: LAN1
Row 2: LAN2
Row 3: DMZ
Row 4: WAN1 -
ok, Thank you,
sn't it necessary to make a policy?ok, i define the port as WAN2 and connect the ISP to it,
Then how do I load balance?
The USG100Flex only has one Native untag WAN from what I can tell making P6 show as WAN does not change it type for internal to external for it to connect to a gateway.
You can however add a VLAN to WAN base port for another external and you will need a switch to likely untag it to the internet.
@dirodiro mr @Zyxel_Jeff decided that my post was the answer.
Did help solve your problem?0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
