GEO IP update error (firmware V5.37(ABFW.0)
2»
  • a1601
    a1601 Posts: 30 image  Freshman Member
    I seem to understand a little. The device has configured WAN reservation through rules, traffic from subnets is normally regulated by them. But the traffic from the device itself does not fall into the existing rules. And the device "does not know" through which interface to send requests.
    How to configure it correctly through the rules so that requests from the device go through the current active interface?
    PeterUK Posts: 4,459 image  Guru Member
    make two new rules In routing make them the top rule
    incoming ZyWALL
    service HTTP/HTTPS
    next hop your WAN interface
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @a1601
    Many thanks for your discovery so far. Please let us check it and kindly wait for our update.
  • Zyxel_Jeff
    Hi @a1601
    We notice the WAN2 interface cannot ping to 8.8.8.8, therefore when the firewall tries to resolve the Geo-IP DB URL(cdn.cloud.zyxel.com) by 8.8.8.8 through the WAN2, and will be failed. We suggest you can configure ping connectivity for 8.8.8.8 on WAN1 and WAN2 at the same time to ensure the DNS resolution behavior can work normally.
  • a1601
    edited August 2023
    Yes, it works! I created for the device two new rules for WAN1 and WAN2 interfaces, similar to the rules for managing a local networks. For these rules, I created the special service group, to which added NTP, HTTP, HTTPS and DNS (do need to add any other services?). NTP and GeoIP are successfully updated now. Many thanks for the help!
    DNS I don't think works by incoming ZyWALL rule
