What is the difference between the NWA110AX and the WAX510D-E ?
melahel
melahel Posts: 2 image  Freshman Member
edited May 2024 in Wireless
Could you explain me what is the difference between the NWA110AX and the WAX510D-E ?
Best regards
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    edited August 2023 Answer ✓
    Hi @melahel ,
    Thank you for your interest in Zyxel products. We assume that you asked about WAX510D model.
    Both models NWA110AX and WAX510D are designed with the WiFi 6 technology and have similar capabilities in terms of speed (2.4 GHz 575 Mbps and 5 GHz 1200 Mbps), PoE efficiency, and 4G/5G coexistence.
    The choice between the two would depend on specific business needs, especially in terms of management flexibility, deployment scenarios and output power.
    Management flexibility:
    • NWA110AX: allowing users to switch between standalone and cloud-managed modes.
    • WAX510D: offering flexibility to switch among standalone, controller-managed, and cloud-managed modes.
    Deployment scenarios:
    • NWA110AX’s embedded antenna: Wall-mount and Ceiling-mount
    • WAX510D’s dual-optimized antenna: Ceiling-mount only
    5GHz’s Output power:
    The WAX510D has a 5GHz output power of 26 dBm, which is 3dBm higher than the NWA110AX's 23 dBm. This means that the WAX510D can potentially offer better signal coverage.
    For more detail information, please refer to the datasheets:
    Zyxel_Judy
    Untitled Image
  • Patric_Groth
    Patric_Groth Posts: 1 image  Freshman Member
    First Answer First Comment Second Anniversary
    I think this content is wrong.
    This the is the rigth Deployment scenarios:
    • NWA110AX’s embedded antenna: Ceiling-mount only
    • WAX510D’s dual-optimized antenna: Wall-mount and Ceiling-mount
    Repaly to this comment
  • Zyxel_Judy
    Hi @melahel ,
    Zyxel_Judy
    Untitled Image
  • Patric_Groth
