GS1200 - ability to show port error statistics?
Is there any ability to show port error statistics with the GS1200 switches? I imagine that this basic statistic has to be buried somewhere.
Thanks!
Edit: I've noticed some interesting things in /link_data.js. Example:
var Stats = [ ['65432',0,0,0,'256','65432',0,0,0,'256',0],
Is one of these packet errors?
Hello @devsec
Currently, the Switch GS1200 doesn't have the error counter functions as per its defined design.
As for the
Statsarray you found in the /link_data.js file, it doesn't represent packet errors. Instead, it likely corresponds to the Per Port Status section of the switch's interface.For instance, consider the following data:
var portstatus = ['Down','Up','Down','Down','Down','Down','Down','Down'];
var speed = ['0 Mbps','1000 Mbps','0 Mbps','0 Mbps','0 Mbps','0 Mbps','0 Mbps','0 Mbps'];
var Stats = [
['65432',891,0,0,'256','65432',658,0,0,'256',0],
['65432',0,0,0,'256','65432',0,0,0,'256',0]];In this data, the second sub-array in
Statscorresponds to Port 2, and the '891' and '658' values in this sub-array likely represent the number of transmitted (TX) and received (RX) packets, respectively.Please see the screenshot of the Switch GS1200-8 HPv2 Web GUI below, which shows 891 TX packets and 658 RX packets on Port 2.
I hope this helps clarify your question. If you need further clarification, please don't hesitate to ask.
Nami
Hello @devsec
As for the
var Stats = [
Nami
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
