limit bandwidth for specific vlans
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
At a customer we use a site to site vpn connection. In the near future we will use an scan device, which creates very large files, which have to send over this site to site vpn connecion. I'm wondering is it possible when i put this scan device on a specific vlan, can i limit the bandwidth usage over this vpn connection, just from this specific vlan?
We use on one site the zywall 110, on the other site usg flex 500.
yours, dennis
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    It's feasible. you can select the VLAN as the Incoming Interface, and select the VPN connection as the Outgoing Interface for your BWM rule.
    Yes its possible not that I have done it but the options for BWM are their to limit such traffic
  • Zyxel_James
