Zywall 310 - 2 ISP by PPPoE on 2 different WAN ports using vlan 7
ktrnka
ktrnka Posts: 1 image  Freshman Member
Is there any chance to setup a vlan 7 on 2 WAN ports(Base Port 2 + 6) as I need to connect 2 modems both needig vlan 7 to connect.
Thanks so much
BR
K.
    PeterUK Posts: 4,411 image  Guru Member
    You would be in the position to know if you can't you need a VLAN switch to untag one
  • Zyxel_Cooldia
    Hi @ktrnka ,
    it is unable to configure same VLAN ID on different eth interface.
    Please add a management switch with vlan support for 2nd wan interface.
