Device Insight.
@Loek it clarified that it's not a display issue and the daemon works fine.
For further checking, I would like to directly check on your device, you may contact me via private message, thanks.0 -
@Loek I found that Fast Forwarding is enabled in your configuration, and it stops the service of Device Insight.
Enabling Fast Forwarding is to the NAT/Routing/firewall performance, but the sessions will bypass scan & control for some features, Device Insight included.
Please disable Fast Forwarding, re-enable Device Insight, reboot the device, and detect again.0 -
That did the trick. The list is populating again. Thanks @Zyxel_James
- 588 USG FLEX H Series
- 476 News and Release
