VPN Cli Command
Fred_77
Fred_77 Posts: 141 image  Ally Member
5 Answers First Comment Friend Collector Fifth Anniversary
Hi all,
my question is: is there a cli command to reconnect a dropped vpn (ipsec site-to-site)?
my issue: atp 100 is in a customer HQ; usg 60 is in branch office.
Since a brand new ftth line has been installed in branch, vpn drops often and even if "nailed up" option in enabled, sometimes vpn fails reconnect and a manual action is required.
But it means : customer call (not so happy), remote connection to atp and manual click on "Connect".
If a i could provide a script to the customare, he could reconnect vpn itself.
Thanks in advance
Fred
  • Zyxel_Emily
    edited August 2023 Answer ✓
    Hi @Fred_77,
    Here is the command.
    Router> configure terminal
    Router(config)# crypto map dial <VPN connection name>
  • Zyxel_Emily
    Hi @Fred_77,
  • Fred_77
    Hi @Zyxel_Emily
    thanks for your reply,
    i forgot to mention a second question: is there a command to login on to ATP?
    The goal should be create an "icon" where the user click on to "easy" reconnect dropped vpn without any other request or input.
    Fred
  • Fred_77
    😴 Ooops… next time "Think Before Talk"…
    Obvioulsy is sufficient to insert the parameters in the connection string. 😫
    Sorry…
    Fred
