VPN Cli Command
Hi all,
my question is: is there a cli command to reconnect a dropped vpn (ipsec site-to-site)?
my issue: atp 100 is in a customer HQ; usg 60 is in branch office.
Since a brand new ftth line has been installed in branch, vpn drops often and even if "nailed up" option in enabled, sometimes vpn fails reconnect and a manual action is required.
But it means : customer call (not so happy), remote connection to atp and manual click on "Connect".
If a i could provide a script to the customare, he could reconnect vpn itself.
Thanks in advance
Fred
Hi @Fred_77,
Here is the command.
Router> configure terminal
Router(config)# crypto map dial <VPN connection name>0
Hi @Fred_77,
Router(config)# crypto map dial <VPN connection name>0 -
Hi @Zyxel_Emily
thanks for your reply,
i forgot to mention a second question: is there a command to login on to ATP?
The goal should be create an "icon" where the user click on to "easy" reconnect dropped vpn without any other request or input.
Fred
😴 Ooops… next time "Think Before Talk"…
Obvioulsy is sufficient to insert the parameters in the connection string. 😫
Sorry…
Fred
- 441 Beta Program
- 292 Service & License
