What is maximum number of VLAN attached per port and added per switch unit (XGS1930)
Steave
Steave Posts: 1 image  Freshman Member
I'm interesting in XGS1930 / XMG1930 and have found topic:
Setup Wizard - Configure XMG1930 Series
on knowledgebase Unboxing and Initial Setup.
Cannot get meaning:
3.2.1 Create up to 5 VLANs by entering VLAN ID (2-4094)
Does it mean 5 VLAN is maximum used by this model?
So what's the limit of VLAN attached per port/switch 1930 series?
Typically it is at least 256 from 1-4094 range.
Does it different among same lineup?
