L2TP vpn from iphone
ITB_Tony
ITB_Tony Posts: 12 image  Freshman Member
First Comment Seventh Anniversary
edited April 2021 in Security
Hi i want to connect an Iphone via L2TP vpn, but it cant connect, getting error
It works fine from android phone, and windows 10.
What PH 1 and PH 2 settings should i use for Iphone?
/Tony
  • [Deleted User]
    [Deleted User] Posts: 118 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Dear @ITBiten
    Apple demands a higher proposal set..
    that means you need to configure any set below in fase 1 and 2
    DH Group
    14
    14
    14
    14
    5
    5
    5
    Encryption algorithm
    AES256
    AES256
    AES256
    AES256
    AES256
    AES256
    AES256
    Hash algorithm
    SHA256
    SHA1
    MD5
    SHA512
    SHA256
    SHA1
    MD5
  • ITB_Tony
    i have set this, and local policy is wan ip.
    still dont get it too work? get this error [COOKIE] Invalid cookie, no sa found.
    Phase 1 IKE SA process done.
  • ITB_Tony
    Thanks that worked.
