How to Configure a Local Guest User for Monitoring Firewall Settings on an ATP100?
Hello Zyxel Community,
I am currently using an ATP100 firewall and I would like to configure a local guest user account that has read-only access to the firewall settings. The purpose is to allow this guest user to monitor the firewall settings without making any changes.
Could anyone guide me through the steps to achieve this? Is it possible to set up such a user account with restricted permissions on an ATP100?
Thank you in advance for your assistance.
Best regards,
Davide
Hi @DavidePon
maybe a user with "limited-admin" privilleges might fit with your requirement.
In case:
Go to Configuration ⇒ object ⇒ user/group
and add the user in the "User" panel.
From the drop down menu "User Type" you can select " Limited Admin"
Hope this can help
Fred
Hi @DavidePon
In case:
Hope this can help
Fred
Dear Fred,
Thank you so much for your detailed guidance! Your instructions were incredibly helpful, and I was able to successfully configure a local guest user for monitoring the firewall settings on my ATP100. I really appreciate the time you took to assist me.
Best regards,
Davide
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
