Problem with L2TP OVER IPSEC USG20
Hi @Ric,
If you're using ZyWALL USG 20, just use Default_L2TP_VPN_GW and Default_L2TP_VPN_Connection to configure L2TP VPN.
Default_L2TP_VPN_GW
Make sure My Address is correctly configured. Configure your own pre-shared key.
Leave other settings as default settings.
The local policy is the wan IP of your ZyWALL USG 20.
Create a new user account for L2TP connection.
Create a pool for L2TP VPN clients.
Note that the pool cannot conflict with any WAN/LAN/DMZ/WLAN even if they are not in use.
After L2TP VPN is correctly configured and established, the L2TP client is able to ping device in LAN (ex: 192.168.1.33).
If you’re using USG20-VPN, just follow the steps in wizard to finish L2TP settings.
Alfonso said:Hi @Ric
Welcome to the forum.
Does any device get an ip address when it connects?
Can you provide any kind of further information?
Have you tested from an android device?
RegardsHi @Alfonso,
Each device receives an IP address
I tried with an Android device, both wifi and 4g, 1 PC win10, 1 PC winXP.
I try to do other tests.
Remote devices have different IPs than the internal destination.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
