Can't access to new Flex 100 after config restore
New Flex 100 with fw 5.37/5.36p2.
Restore config from other Flex 100.
After restoring i get adress via DHCP, but cant ping\access ssh\https to device.
After connecting via console, disable firewall rules - not helped.
Cant ping other device, get
ping: sendmsg: Operation not permitted
Hi @alexey
"After connecting via console, disable firewall rules - not helped"
You can use CLI: to disable the firewall rule.
Router> configure terminal
Router(config)# no firewall activateBesides, you can use the below CLI to check the device GUI's https and SSH access port.
Router# show ip http server secure status
Router# show ip ssh server status
Thanks.
I wrote, that i disabled FW via console port and it not helped🙉.
ZW device can't ping other LAN devices with message
What this mean? That you broke another time your devices with new FW?
After reset to default config i can access to device.
After i restore config again - i can't access to device.
And why device not permit ping?
Router> show interface all
No. Name Status IP Address Mask IP Assignment1 vpn1 Down 192.168.78.100 255.255.255.0 Static
2 vpn2 Down 10.0.0.78 255.255.255.0 Static
3 local 1000M/Full 172.20.78.1 255.255.255.0 Static
4 dmz Inactive 0.0.0.0 0.0.0.0 Static
5 guest Inactive 0.0.0.0 0.0.0.0 Static
6 vti0 Up 10.1.0.66 255.255.255.252 Static
7 vti1 Up 10.1.1.66 255.255.255.252 Static
8 vti2 Up 10.2.0.66 255.255.255.252 Static
9 vti3 Up 10.2.1.66 255.255.255.252 Static
10 vti4 Up 10.3.1.66 255.255.255.252 Static
11 vti5 Up 10.3.0.66 255.255.255.252 Static
Router> ping 172.20.78.2
PING 172.20.78.2 (172.20.78.2) 56(84) bytes of data.
ping: sendmsg: Operation not permitted0 -
Hi @alexey
It could be related to the configuration file. Could you provide the USG Flex100 configuration file to us via private message? Maybe we can reproduce this symptom and troubleshoot it for you.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
