VPN Configuration Provisioning with DHCP public IP
Hi @Line2,
In VPN gateway, use domain name as My Address.
After ikev2 is connected, it shows the domain name in Server on iOS.
5
Hi @Line2
Congratulations. IKEv2 road warrior sounds great.
I got it with another brand, but most of my clients are Android, and they needed to install a certificate.
For non root on Android devices it was a problem, so i came back to a L2TP/IPSEC road warrior.
AS far as I know, only clients need to know the public ip address (or the FQDN) of the road warrior server. So, no new configuration would be necessary on the Zywall.
Why do you want to configure FQDN instead the public ip address?
Cheers0 -
I already use IKev2 for Clients with Active Directory Authentication on Apple iOS Devices with certificate auth in phase1. No problem with that using Apple configuration profile. But not with ZyXEL configuration provisioning.ZyWALL has no fix IP address on WAN interface, so FQDN is CNAME to a dyndns address.1
Hi @Line2,
5 -
ok, thank you.
- 588 USG FLEX H Series
- 477 News and Release
