Routing a two subnets through a two different WAN ports with mutual redundancy
a1601
a1601 Posts: 30 image  Freshman Member
Hello!
I need qualified advice how to organize the following scheme of work.
There are two Internet channels, connected to WAN1 and WAN2 (conventionally WAN1 - main channel, WAN2 - backup).
In "normal" mode subnet 192.168.1.0 (1) is routed through WAN1, subnet 192.168.4.0 (4) - through WAN2. This is solved by setting routing rules.
If link on WAN1 fails - the routing rule for WAN1 is disabled and the next rule for WAN2 starts working to switch the routing from network 1 to backup WAN2 (this is also solved by checking the availability in the rule for the WAN1). At the same time subnet 4 also continues to work through WAN2, everything is fine.
But if fails the backup channel WAN2 - need to switch subnet 4 to the main WAN1 - this is where the problem arises.
If i configure the rules to check the availability of WAN2 (to enable the next rule for routing subnet 4 to WAN1) - the check (ping 8.8.8.8 or any other) does not pass in the "normal" mode, this rule is immediately disabled (although channel 2 is working).
Is it possible somehow to make such a mutual reservation of channels for different subnets or is it impossible?
Policy routes:
policy 1
description ZYXEL-WAN1
interface ZyWALL
dscp any
service ZYXEL_SERVICE
next-hop interface wan1
auto-disable
conn-check 8.8.8.8 method icmp period 5 timeout 1 fail-tolerance 1
conn-check activate
policy 2
description ZYXEL-WAN2
interface ZyWALL
dscp any
next-hop interface wan2
policy 3
description LAN1-WAN1
interface lan1
dscp any
snat outgoing-interface
auto-disable
conn-check activate
conn-check 8.8.8.8 method icmp period 5 timeout 1 fail-tolerance 5
policy 4
description LAN1-WAN2
interface lan1
dscp any
policy 5
description LAN2-WAN2
interface lan2
dscp any
auto-disable
conn-check activate
policy 6
description LAN2-WAN1
interface lan2
dscp any
Thanks in advance!
  • a1601
    Sorry again, I misled you. I found my mistake in the settings, everything works as it should now. Thanks for the help!
    PeterUK Posts: 4,411 image  Guru Member
    edited September 2023
    It should work what you have done...if you unplug WAN2 LAN2 should use WAN1
    Maybe change one of the ping to 8.8.4.4
    There is this firmware saying about a fix for fail over
    https://community.zyxel.com/en/discussion/18656/zld-v5-37wk30-firmware-release#latest
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Yes, I think your routing configuration can work.
    When WAN1 fails, policies 1, 3, and 6 would automatically disable themselves, and both would be routed through WAN2, and vice versa.
  • a1601
    But when both WAN1 and WAN2 work and Enable Connectivity Check for policie 5 - it policie is disabled and both networks routed through WAN1.. (need routed LAN2 through WAN2). Connectivity Check disabeled - it works.
    Pinging another IP for check (8.8.4.4) - it didn't help.
    Maybe I'm missing something?
    So with ping check working the following happens
    LAN1 goes out WAN1
    LAN2 goes out WAN2
    ping check fails on WAN1
    LAN1 goes out WAN2
    LAN2 goes out WAN2
    ping check fails on WAN2
    LAN1 goes out WAN1
    LAN2 goes out WAN1
  • a1601
    Yes, everything is described correctly, that’s exactly what I want to do. But for some reason it doesn’t work and I don’t understand why.
    so if you put in a test IP where the ping will fail like 127.0.0.2 this will fail the check for testing.
    So what is it your seeing? LAN2 when ping is fine not going out WAN2?
  • a1601
    Ping check for any IP (8.8.8.8, 8.8.4.4 and other) for policies LAN2-WAN2 is fail.
    Settings:
    Result (WAN1 and WAN2 works fine, LAN2 going out WAN1):
  • a1601
    Sorry, today my tests are incorrect, because in reality there are problems with the provider for WAN2. I'll check again later.
  • a1601
